I use TetGen for difficult STL. It identified two small areas with self-intersecting shells, which nothing will want to mesh. Once corrected it meshed fine.
That "h" bug should have been fixed in v17. So please update to the latest one if you haven't. Otherwise, could you send me the file to find out why it's still doing that?
However, it won't help the meshing and just show a generic error message.
If material properties require shell/membrane, that means the mesh is shell elements, not solids. You might have only a surface mesh.
