Mecway 36 is now available at the link below and includes the Spanish language manual translated by Germán Bresciano.
https://mecway.com/download/mecway360.msiThis supersedes version 35 because it had a serious bug (see below). This is still a release candidate so it has a higher risk of new bugs. If no serious bugs are found, it will be promoted to a stable release, otherwise it will be superseded by version 37.
GUIWider output window in external solver monitor.
OpenRadiossVon Mises stress for shells.
FemasterDoesn't use ROT NODE.
Writes temperatures for thermal stress.
Reads element node values.
Reads rotation X,Y,Z
Reads shell stress at top/midsurface/bottom.
Code_asterNonlinear static 3D with beam, truss, spring, 6 DOF spring, tension-only, gap, and quadratic shell elements.
APINew function solution.set_element_node_variable() to set values at element nodes.
New function mw.liml_text() to save as liml format to a string.
Bug fixesNode-surface coupling with no faces caused a crash.
A material with no mechanical type exported to bdf would crash.
