Mecway 36
Mecway 36 is now available at the link below and includes the Spanish language manual translated by Germán Bresciano.
https://mecway.com/download/mecway360.msi
This supersedes version 35 because it had a serious bug (see below). This is still a release candidate so it has a higher risk of new bugs. If no serious bugs are found, it will be promoted to a stable release, otherwise it will be superseded by version 37.
GUI
Wider output window in external solver monitor.
OpenRadioss
Von Mises stress for shells.
Femaster
Doesn't use ROT NODE.
Writes temperatures for thermal stress.
Reads element node values.
Reads rotation X,Y,Z
Reads shell stress at top/midsurface/bottom.
Code_aster
Nonlinear static 3D with beam, truss, spring, 6 DOF spring, tension-only, gap, and quadratic shell elements.
API
New function solution.set_element_node_variable() to set values at element nodes.
New function mw.liml_text() to save as liml format to a string.
Bug fixes
Node-surface coupling with no faces caused a crash.
A material with no mechanical type exported to bdf would crash.
  • edited November 16
    I love the integration of new solvers such as Femaster and Code_aster. Mecway has became a Swiss Army knife for FEA guys.
