I'm playing around with orthotropic solids and made a simple test model to see where the material constants map into Engineering Constants in the CCX input file. They appear where expected except that the nu12 is mapped twice (nu12 and nu13) and the value for nu13 does not appear. Is this a bug or am I missing something? I've attached the model, the CCX .inp file and the material input dialog.
nu12, nu13, nu23
whereas in Mecway they are
nu12, nu23, nu31
For exporting to .inp, Mecway converts nu31 to nu13 using the formula
nu13 = nu31 * E1 / E3
It's just a surprising coincidence that nu13 = 0.3 * 1/3 = 0.1= nu12 in your test!
Directions 1, 2, 3 correspond to U, V, W as you'd expect.
I have read one paper about Poisson's ratio in orthotropic materials which exposes some constrains in between their values.
Now I understand better why there is sometimes a warning when introducing certain combinations of Poisson values. The warning says : “Material Stiffness Matrix is not positive definite. Poisson’s ratios might be too large”.
That paper shows a different relationship between the corresponding symmetric terms.
nu13 = nu31 * E3 / E1
By other hand I do not understand yet which of the criterias are checked. I have found some combinations that should warn the user, but it doesn’t .
Find example.
@disla You've run into an even more insidious problem in that there are two different conventions that both use the same name and same notation but transpose the values! Your document and its source use the other convention in which ν_ij = ν_ji in Mecway's convention.
The popularity of each convention seems to have reversed sometime around the 1980s for some reason. The paper your document cites is from 1968 and uses the older convention.
The test Mecway uses for that error message looks at the material stiffness matrix itself, not the individual Poisson's ratios.
The core modeled is the first on listed for 5056 aluminum in appendix 1. It has a cell size of 1/4 inch and a ribbon thickness of 0.001 inch with a thickness of 0.002 for elements aligned with the ribbon direction from the manufacturing bonding process. The solid hex8 core is modeled using the method in the second pdf. The two FEM models and the empirical calculation give results close to one another.
This work is out of interest and now that I'm retired, I have time to go down these rabbit holes. When I was a stress analyst for F/A-18 aircraft, the model from the late 1970's was very coarse and used a proprietary McDonnell Douglas FEM program named CGSA that ran on a MicroVAX. The honeycomb parts were modeled using membranes and rods for the skins and were around 2 inch square. The shear panels for the core were attached to the skin element nodes and ran in the ribbon and perpendicular directions. The thickness of the shear panels was average of the distance to the next shear panels and had shear properties from the core shear modulus. I knew there had to be a better way to model honeycomb parts given the advances in computers and FEM software. It is amazing how I can run such large models in a few minutes on my laptop where it took many hours to run smaller models back then.
Ken
Young engineers today can't imagine that you started your model one line at a time: node, x, y, z (repeat a few hundred times).
My first job was with Lockheed and we used punch cards. Computers were big, processors weak, memory small, run times enormous. Tools like Mecway and Calculix make quick work out of things that would take an order of magnitude longer in the old days!
Really nice post.
I recently realized that applying symmetry boundary conditions to Orthotropic or Laminated elements couldn’t be safe as it changes the fibers direction, and it is not correct ¿isn't it?.
¿How do we manage this?.
I guess it could be solved orienting the properties orthogonal to the axis of symmetry, but I,m working on some examples with laminates at 0º/+45º/-45º/0º and weird combinations. That’s what remind me this Ken post but his example is and orthotropic core with U V properties being the same, so I think here it’s safe.
I’m doing some validation before proceeding with Calculix/Mecway so I’m not completely free to choose the configuration.
I have clear now that I will avoid symmetry BC for Laminates or Orthotropic elements just in case.
I’m obtaining a big difference between the quarter, the half, and the full plate. I have found now some warnings on the book I’m following even for othogonal fibers 0/90.
