Beam element implementation on CCX
Hi Guys
A massively huge thank you to Victor for providing the functionality in Mecway so that my custom build of CCX can run!!!!
If you are interesting in using the distribution refer to the below link to the custom build of CCX.
To get access to the beam elements, extract the zip file, point Mecway to the CCX exe file.
Activate the extra beam features as shown in the image below.
Use a custom element type, which can either be B31E or B31T (euler bernoulli or Timoshenko)
The results seem really promising, these is an issue with rectanuglar sections where the section is orianted incorrectly, however it seems to be working well for all other elements. There is a test case in the folder shared below which shows the accuracy. The "CCX prior build" was an old build which had some issues with the torsional constant was handled.
https://drive.google.com/drive/folders/1H78SCM9srGph3yHTyfV0fAB74iey-1q-?usp=drive_link
  • Dear @Mishal thanks for bring us this new capacities for Mecway! I have run your test case with all bc as they are (except removing the CCX custom element) using internal solver and the new CCX with beams, but I don´t understand why the deformation is reversed, see the pic
  • @Sergio apologies, the build for the .exe may be an older version. I will share the correct one tomorrow when I am my laptop
  • edited November 5
    I have run another model and results agree very well with internal solver, Code_Aster and FEMaster as well, this is a very good new.
    @Victor , as we have so many solvers to choose, would be great to have a title block in the post view showing the solver (and version maybe) used. At least a new line over the variable name of the postprocessed variable.
  • @sergio, I have run some checks, it seems that you may be using an older version of the .exe (possibly one from the CCX forum).
    The link to current distribution I have shared prodcues the correct results for your first post. If there are still issues after checking your ditribution please let me know and we can look into it.
