Hello everyone!
I'm facing some problems when trying to use cyclic symmetry in a tank analysis.
I have to check a tank for hydrostatic pressure and dead load of componentes, but couldn't figure out how to use cyclic simmetry. I tried remesh with several different parameters, tried using gmesh, importing meshs from other softwares but always end up in the same spot: "Incompatible constraints on nodes xxx".
The boundary conditions are simple: fixed bottom plate and hidrostatic pressure inside tank.
Model was made in solidworks using surfaces, imported into Prepomax to create an unique body step file and then imported into mecway.
Problematic nodes: nothing special about them (as far as i can see)
Both master and slave surfaces have exactly same number os faces = 352.
I attached the mecway file if anyone try to help me.
Thanks in advance,
Rafael
I also attached the step file that i used
