Bonded Contact alternative
Hello all,
we have a model with about 800.000 nodes that incluedes about 100 parts. Many of these partes are connected to one another by adhesive bonding. To connect the mesh of the adhesive to the mesh of the components we use bonded contact.
Unfortunately, the model becomes very slow. Running for 65 hours now and still "applying constraints".
Is there any way to speed up the bonded contact or, alternatively, is there a clever way to create compatible meshes in complex assemblies so that the adhesive may share commen nodes with the components to avoid bonded contact alltogether?
Thanks a lot for any advice!
  • @Sergio found a way to make compatible meshed with Gmsh, described here https://mecway.com/forum/discussion/808/conformal-meshes-with-gmsh
    Sorry it's so slow. The delay is in generating the MPCs and is caused by the inefficient way it accesses the system matrices so there's not much you can do besides using fewer nodes in the bonded contacts.
    Can you use the CCX solver? It's much faster at MPCs. For 800 000 nodes, you would probably need to compile the MKL version with OOC whose source code is included with Mecway. I'm not sure if we've talked about this before but compiling it with that is pretty easy and only requires installing one extra thing (Mingw64). Or if you have enough RAM (~100 GB?), it should solve faster with an ILP64 (i8) version of CCX that I think is available at dhondt.de.
  • Hi @Victor
    thanks for the advice. I will look at the post by @Sergio.
    I already fiqured out that the bonded contact is much slower when the meshes are very different compared to nearly compatible meshes.
    We may give ccx a try. But we are using laminate materials and sheetmetal parts that we model with shell elements. With ccx I am always a bit uncomfortable with shells because thay seem to be a bit buggy and shells with laminate are incompatible with some elements that we need to use (e.g. *mass)
    We will try to get in compiled and see how it works. We have 64 GB RAM
    Our other alternative is to rebuild the entire model with solids only and use common nodes for adhesive and component.
  • edited June 2023
    Fair enough about CCX shells. Some of their problems are related to rotational DOF and transformed (non-global-axis-aligned) constraints and often there are alternatives to those. For bonded contact, the elastic option is the most reliable for shells.
    The version of CCX with Mecway 19 (and the source) is patched to allow all other element types except user elements to be used in the same model as laminates.
  • @kuhl, I've fixed the unreasonably poor performance for bonded contact in static analysis in an update here https://mecway.com/download/mecway200_Beta3.msi (v20 beta 3)
    For example, a 100 000 node model with 12 000 bonded contact slave nodes that used to take 25 minutes for the Applying constraints stage now takes 25 seconds.
  • Hi @Victor ,
    if that works that would sure be a major game changer. We'll check it out and let you know.
    Thanks for looking in to this!
  • @Victor ,
    that fix worked incredibly well on a test model that we set up. Thank you very much!
    Top: V19, Bottom V20_Beta3
    3510 sec. vs. 37 sec. for applying constraints phase. Thats 95 times faster.
    For curiosities sake: what was the issue before?
    And is the beta version "safe to use" for 3d static" simulation?
    Thanks!
  • The previous versions would apply each term of each MPC to the system matrix by making a dense copy of a couple of entire rows and operating on every value, despite the matrix being sparse. That lead to millions of redundant multiplications by 0 for each MPC term. The new one exploits their sparsity
    Yes, it's OK for regular use of all the features. Every release I make, including special in-between versions like this, passes a comprehensive set of automated tests for the solvers. Sometimes there might be GUI or random crashing bugs which aren't well covered by test cases, but probably no new ones here.
  • Hi @Victor
    Thanks for the background info, that makes sense.
    In the meantime we have been solving a model we are currently working on in under two hours with beta release that previously wouldnt solve within 90h. We were actually just about to give up.
    So thanks again for the great support.
    Speaking of bugs:
    I noticed that model edges do not hide in beta version.
  • Ouch. Sorry it's been such a time-waster. I didn't quite realize how serious it was until you mentioned 65 hours.
    The not hiding model edges is intentional. Some people have said they want an awareness of where the non-hidden parts are so I thought leaving that visible would do that, and you could turn it off most of the time if it's in the way. It also used to show a lot of unhelpful edges on the ragged cutting plane surfaces. Will that be OK or is it a real problem for you?
  • Until now the models alway s solved over nicht, so that was Not too bad...
    Now that you mention it leaving the model edges visible might be a benefit for post processing to have the hidden parts "transparent" for reference. Cant really say if it might be annoying in some situations right now. I'll let you know what i think of it once I have worked with it for a while.
    Maybe an option to toggle the visibility of the hidden component's model edges in the preferences would be an option.
    Back to bonded contact:
    I noticed that the visualization performance gets bogged down quite a bit when selecting a bonded contact in the outline tree even If it does not include many nodes. Might there be a fix for that, too?
  • edited June 2023
    Haha, the fix for slow display of bonded contact was to not display the little circles and lines, which I did for one version. But people didn't like that so it's back ;)
    The slowness there is because it's matching up the nodes, faces, points on faces, etc. in the same way the solver does. It was meant to give a reliable visualization of which nodes connect to where. But perhaps nobody really needs that and simply showing dumb symbols on each face would be sufficient.
    No doubt it can be improved but I don't see it as such a high priority. I just try not to click on bonded contacts.
  • Oh this is great!
    I've never really used the inbuilt solver in part because it seemed so incredibly much slower than CCX (and because I often need nonlinearity) but that may be caused by me often using bonded contacts as most analysis consist of multiple STEP files from my CAD software which are bonded rather than being modeled as a single piece.
    This may lead to me using the inbuilt solver more. :D
  • @Victor , I just noticed that with beta version clickin on the "ok" botton causes Mecway to get stuck.
    Back to the always visible model outlines: They do get in the way quite a bit if there are many components in one model. So having an option to "hide" or to "hide all but outline" would be a nice addition.
  • Which OK button?
    I might have to rethink the outline. Though don't forget you can make it thinner in Tools -> Options.
  • This Button:
    It is not there in V19. I thought it was intended to save the sum in outline tree or something like that...
  • Yes it's meant to do that. It doesn't get stuck when I try it. Do you mind describing the steps to reproduce the problem?
  • For a small test model it worked just like you intended. On a large model the curser kept spinning (as in the software is working on something) and I shut mecway down after waiting about 10 min coz I thought there was someting wrong.
  • Oh. It might be too inefficient evaluating it. I'll have a try with a big model. Did you have a lot of time steps in the solution? It finds it for all of them so in those cases it'll be slower than before.
  • It's apparently instantaneous for me with a 180 000 node model and 50 000 constrained nodes having reaction force summed, so maybe something else is breaking it. Would you be able to send me the file privately?
  • No, no time steps.
    I tried again and gave it more time. This time it worked. Don't know why its taking so long in this model (600k nodes). Maybe because of several configurations?
    Sorry, I can't share the model.
    Can the sum be defined before solving? It would be handy to have it available strait away.
  • Could you at least show me the whole outline tree, so I can see what things are present?
    Yes, once it's there, it'll be now evaluated when it solves.
  • Hi @Victor,
    That is a very convinient feature!
    I sent you a mail with the outline tree.
