Hi all,
I have been long time looking for a nice GUI for Code-Aster. I have been using Salome-Meca, but always find it too tedious to use. In the first half of this year I established the working principle of a bridge between Mecway as pre-/post processor and Code-Aster as a solver. That structure proved to work. After that I didn’t have time to spent on it until last week. My son is programming a lot with Claude Code, and this week he didn’t have time to use it because of his homework 😊. So I was allowed to spent his weekly limit. Unfortunately, it worked out quite well and I decided to unlock more of Code-Aster than I normally use. As a result, the MecwayAsterBridge grew quiet large in capabilities. You can find it here:
https://github.com/trednuK/MecwayAsterBridgeI have added a lot of validation checks and documentation. However, since it is build by AI, it still needs human verification to find edge cases which only appear in daily use.
Kind regards,
Kundert
â•‘ â•‘
â•‘ â•‘
â•‘ Erreur de syntaxe dans AFFE_CHAR_MECA â•‘
â•‘ â•‘
â•‘ At least one argument of ('TOUT', 'GROUP_MA', â•‘
â•‘ 'GROUP_NO', 'NOEUD') must be defined â•‘
â•‘ â•‘
║ Exception détaillée ci-dessous. ║
I did wonder if it is something to do with defining points or surfaces and played around but got now where. Is there something obvious I'm doing wrong? I have attached a sample of a simple model that i have got stuck on
1:11AM
@Fatmac , I just remove the CCX custom card and apply the restrain to the defined face group (it was applied to the same faces but selected directly) and then works ok.
thanks Sergio - that appears to be all that was wrong -that has open the door to more fun!
I am not sure about TIE with shells. I will look it up for you, but give me some time.
In the meanwhile, you could try using normal Code-Aster commands via #Aster-keywords (you can read about it in the help-documents of the bridge). Not sure if that will help, and did not test it myself up to now.
Please refer to the below link. I have not pushed it to my main brach as yet.
@KundertdeWit, I am not an expert with Github (just a basic user) we can possibly merge all our changes at some point, I see that you have updated your repository once already, my fork of yours has had a few changes today.
https://github.com/mishal0488/MecwayAsterBridge/tree/dev
I did the same :-), I was reading your post just now. I checked if my changes cover yours, which is not the case. I will add this to the next release, which will be available tonight I think
Release 2026.2 is available just now, with some other improvements, including Mecway 34.
Could you also check the frequency analysis again (in another forum thread), regarding the orientation of beams.
Thanks for your work and kind regards,
Kundert
I have added some issues/feature request in the Github page, related to add some buttons in the convergence window to access directly to Code_Aster comm, mail and med result files.
This new bridge is incredible, the way bc and results are translated directly is amazing.
I may not make any modification and changes for a while since my workload is currently high.
Many thanks for your valuable input.
It has been added to version 2026.4, which is available now
@Mishal: the functionality has been added, but a bit differently than you did it. Please check if this indeed does what it should do.
