I think something is wrong with Termal steady state calculations.
Look at this very simple model. It is a cube with heat going in through a face of constant high temperature, and going out by the center of the oposite face, at cold constant temperature.
The rest of the surfaces are isolated.
Surface normal integral of heat flux on the hot surface should be exactly the oposit of surface normal integral of heat flux on the cold surface, but it is not.
Surface normal integral of heat flux on the isolated faces should be zero, but it is not.
Surface normal integral of heat flux on all faces should be zero, but it is not.
Surface integrals of heat flux Z on In and Out surfaces give the same results as Surface normal integrals of heat flux.
Where is the problem?
Thanks for all this years of Manual's translation.
Could you post that simple model. I can't figure what's the problem. ?
I think the effect is worsened by the hard boundary of the cold patch so that most of the heat exits around the perimeter where edge effects are stronger.
Let me know if this doesn't address the problem you found.
The difference extruding cold faces is awsome.
