Hi all,
I am having issues with CXX contacts (symmetric model of rod in a hole).
Contacts 3 and 3b (bonded, elastic) cause stress without any load on the model.
It gets worse with increasing contact stiffness (1st image: 2000 GPa/m, second image: 200000 GPa/m
What am I missing?
Some contact definitions are solved as an interference fit. take a look at the adjust parameter.
From the information in the manual I thought that interferences or gaps are dealt with without causing stress, because it says:
"Elastic, CCX solver:
This creates elastic springs between the surfaces. As with Tie, the nodes of the slave surface are
moved in a strain-free way so they lie on the master surface."
