Hello everyone,
I work at a small company and from time to time we need some FEM Simulations. I quiet well know Femap. At work we are just using NX Design Simulation, which capabilities are not that good, especially when you need beams or shells.
I did some reasearch and came to Mecway, which i really like from first views
I downloaded the 1000 Nodes test version and iam very happy with it. When i come back to femap there is some api to idealize bolted connection, which connects each end of a beam element with an RBE2 element to a bunch of pre-selected nodes.
I tried to make a code to recreate this kind of feature.
There are some points where iam getting stuck. I managed to select some nodes and create a mid-node and connect the selected nodes with a line2 element to the mid-note.
I would like to give those beams mechanical properties like youngsmodulus, diameter, rectangular bar, poisenratio, density...
i looked in the api reference "mw.material_property(material, property)", but i didnt got it running so far.
Is there also a way to create a button, to give the user a chance to re-select some other nodes before creating a new mid-node? now it just creates the same beams like before when you continue the code.
I was thinking about the same kind of behavier when you select the open cracks feature. Where is a button to repeat the code after you pressed it or something like that.
I appreciate every kind of comments and help and i wish you a good start into the new year
ps.: attached you see a bolted connection in Femap and the code i made so far.
The problem arise when the user create the second spider, as is now the script, it create the second spider, and a new rigid material, but it doesn´t assign to the new spider. I don´t have the skills/time to fixe it, it should check if the material exist and don´t create a new one.
@Sergio: Nice example of implementing API. Slow time of year, so I tweaked a couple of revisions to your script. Wasn't sure if you preferred:
We have been using Mecway for 8 years now, with many licenses. Rest assured you have chosen well!
Try this...
Lot's of ways to achieve similar results, I assume.
Thanks for sharing your py-files. It really helps me a lot
i have now also made 2 scripts to model the bolted connection.
First you need to make 2 Spiders, one after another, via "Spider_for_Bolted_Connection". Select the nodes first and create a mid-node.
Afterwards activate "Create_Bolt_between_last_2_nodes" by entering the bolt diameter. The bolt is modeled between those notes with the right diameter. And the bolt diameters are all arranged into the Component "Bolt_Mx" where x is the user input.
is there a way to manipulate the units in the files? I like to model in mm and MPA.
Would be great to have a custom tool bar (floating?) to add this kind of scripts, I use several ones and the menu feels a little uncomfortable. Another usefull thing would be the possibility to add a custom tip to the tools, in the menu and/or in this custom tool bar.
