Hi!
This method (CBFEM -
https://www.cbfem.com/) is used by HILTI, IDEAStatica and other web applications for calculating steel connections. Showing the mesh is clear that there is an offset between the shells but I didn't understand how is simulated the bolt (traction and shear and bearing for plate holes) ...see attached pictures.
Some idea?
You could model the bolts as solids and use Pre-tension section on them, and connected to the plates by Contact.
https://www.steelchecks.com/connections/whatis.asp
Then came Idea Statica and spanish
https://info.cype.com/es/software/cype-connect/
and the german
https://www.dlubal.com/en/products/add-ons-for-rfem-6-and-rstab-9/connections/steel-joints/steel-joints-features
https://www.amazon.es/Steel-Connection-Analysis-Paolo-Rugarli-ebook/dp/B079VSGMD8/ref=sr_1_12?qid=1703078116&refinements=p_27:Paolo+Rugarli&s=books&sr=1-12
