I have an imported STEP part which has been meshed. When I select the faces of the geometry part and add them to a surface, the resulting faces selected on the meshed part do not correspond 1:1 to the faces originally selected on the geometry.
In the picture I have selected 6 screw holes and added the surface. But the surfaces that are selected in the mesh are 5 of the 6 screw holes and a fileted edge (red arrow). How can I fix this? Thanks.
https://mecway.com/forum/discussion/942/pinned-support-not-assigned-to-the-right-surface#latest
If you could send me the STEP file, that would really help in the long term since I currently have only one example to test on.
Victor, I am using V14.0 and I have attached the STEP file.
A workaround for now is to do direct selection on the mesh.
