I am trying to export a deformed mesh, and I am having some difficulty. When I run the simulation on a solid body I can export the deformed mesh without an issue, but if I run my simulation as a shell model, I get the error below, and the deformed mesh does not export properly. (Image of deformed result and failed export are attached)
Has anyone else encountered this issue?
Thanks for the help,
Paul
"Warning: The number of nodes in the solution doesn't match the model. Some values may be applied to the wrong nodes."
*NODE FILE, OUTPUT=2Din CCX -> custom step contents.
