I am working on a project with other people and although I am a Mecway user, they are not.
I would like to send them the results (von Mises stress and deformations) for them to look at and keep for later validation.
Currently I have to do it by screenshots which is a hassle.
It would also be beneficial if they could have access to the whole problem definition (e.g. where forces were applied, material properties, bearing conditions, etc). Again, for later validation (e.g. 5 years from now, confirm everything was done properly).
I think what would be great is if the "free" version of Mecway could be used as a viewer, even if the mesh is large. I tried it and it does not work (it does not show the results), but it does allow to confirm the problem definition which is half of the solution. If I could export 3D the results somehow (e.g. to paraview) it would also be OK.
Any ideas?
Thanks in advance!
I tried using the "free" version again and Mecway works exactly as I was requesting, as a viewer.
Apologies and thanks for the great software!
Ricardo
So for now I'm saving a copy of the mecway installer and the project file.
