My question may be raised and answered. I have a nonlinear static simulation in which the load value is changed in each run in order to see displacement. Having the load and displacement values, I can estimate nonlinear stiffness of the model.
How can I implement this do in an "automatic" manner? Thank you.
Is it still possible to use batch file or script to automatically run separate simulations? Just to know an alternative.
Don't can use the internal Python API for this because it doesn't yet have a way to modify the loads or open a file.
1) All file solver
Will solve every .liml file in the directory (you need to set them up manually and then run the batch file)
2) Blind Iterate
You can modify the python code to iterate over variables. For example if you want to iterate over larger and larger loads, in Mecway I would set it up like this
Then the python script will iterate over those variables in whatever way you define and solve the file. It saves the solution as a seperate file, but I don't remember if I have CSV output working well yet.
There's some discussion here about running batch jobs. If you want to take this further, Google "Optimax Matej", you'll find a free code that can automate running a job in batch using any DOS command, including the Mecway batch solve command. You can couple this with a Windows bat file input and vary the input files to run dozens of cases very easily.
