You can enter a piecewise stress-strain curve in CCX -> custom model definition. See the manual section 13.1 Custom model definition for an example using 3 points.
Thank you for your answer. Are there any plans to integrate that oportunity in the Material Properties --> Plastic card as new Point: Strain-Strss-curve
It looks like you already have materials named Stahl and Rotguss which are conflicting with the new ones. Use different names and remove any Mecway-defined materials from the components that are getting the new plastic material.
Don't forget to enter the *SOLID SECTION cards too since Mecway will no longer generate them with no materials on the components.
Yes, I hope to add this to the UI soon to make it easier.
The next version (14) will have a stress-strain curve.
Could you two, and anyone else here, tell me if you prefer the strain input to be plastic strain (0 at yield) like CCX does or total strain (yield strain at yield)?
Thank you as well! I would like total strain as well, especially with the recent speedups. Having a linear part to speed up calculations as well as a non-linear part does not seem as important with the speeding up of the computers, solvers, Mecway and Calculix in recent times. Probably more speed up on the way due to larger memory on GPU cards and faster Pcie busses and different (more adaptive) software models. Can't even go get a cup of coffee while waiting for a solution with Mecway and Calculix. Also most of the materials I use are not precisely linear at all (carbon fiber is close), just defined that way by code to simplify calculations.
as new Point:
Strain-Strss-curve
If I follow your suggestion the inp. file contains the following, but it seems nonlinear material is not taken...
*MATERIAL,NAME=Alu
*ELASTIC,TYPE=ISOTROPIC
70000000000,0.3
*DENSITY
2750
*MATERIAL,NAME=Stahl
210000000000,0.3
*DENSITY
7850
*MATERIAL,NAME=Kupfer
125000000000,0.3
*MATERIAL,NAME=Rotguss
95000000000,0.3
*DENSITY
8700
*MATERIAL,NAME=Bronze
111000000000,0.3
*DENSITY
8730
*MATERIAL,NAME=Messing
90000000000,0.3
*DENSITY
8500
*SOLID SECTION,ELSET=innen,MATERIAL=Rotguss
*SOLID SECTION,ELSET=aussen,MATERIAL=Stahl
other stuff
*AMPLITUDE,NAME=Aconstant
0,1
*ELASTIC
210000000000,0.3
*PLASTIC
350e6,0
400e6,0.01
410e6,0.1
*DENSITY
7850
*ELASTIC
125000000000,0.3
95000000000,0.3
*PLASTIC
250e6,0
300e6,0.01
310e6,0.1
*DENSITY
8700
*STEP,NLGEOM=YES,INC=100
*STATIC
