non-linear material specification
Hello all,
Is there a way to enter a technical stress-strain curve in Mecway to describe a non-linear material behavior.
I thought that would work?
Thanks in advance
  • You can enter a piecewise stress-strain curve in CCX -> custom model definition. See the manual section 13.1 Custom model definition for an example using 3 points.
  • Thank you for your answer.
    Are there any plans to integrate that oportunity in the Material Properties --> Plastic card
    as new Point:
    Strain-Strss-curve
  • I tried your suggestion, but didn't get the expected results :-(
    If I follow your suggestion the inp. file contains the following, but it seems nonlinear material is not taken...
    *MATERIAL,NAME=Alu
    *ELASTIC,TYPE=ISOTROPIC
    70000000000,0.3
    *DENSITY
    2750
    *MATERIAL,NAME=Stahl
    210000000000,0.3
    *DENSITY
    7850
    *MATERIAL,NAME=Kupfer
    125000000000,0.3
    *MATERIAL,NAME=Rotguss
    95000000000,0.3
    *DENSITY
    8700
    *MATERIAL,NAME=Bronze
    111000000000,0.3
    *DENSITY
    8730
    *MATERIAL,NAME=Messing
    90000000000,0.3
    *DENSITY
    8500
    *SOLID SECTION,ELSET=innen,MATERIAL=Rotguss
    *SOLID SECTION,ELSET=aussen,MATERIAL=Stahl
    other stuff
    *AMPLITUDE,NAME=Aconstant
    0,1
    *ELASTIC
    210000000000,0.3
    *PLASTIC
    350e6,0
    400e6,0.01
    410e6,0.1
    *DENSITY
    7850
    *ELASTIC
    125000000000,0.3
    95000000000,0.3
    *PLASTIC
    250e6,0
    300e6,0.01
    310e6,0.1
    *DENSITY
    8700
    *STEP,NLGEOM=YES,INC=100
    *STATIC
  • edited August 2020
    It looks like you already have materials named Stahl and Rotguss which are conflicting with the new ones. Use different names and remove any Mecway-defined materials from the components that are getting the new plastic material.
    Don't forget to enter the *SOLID SECTION cards too since Mecway will no longer generate them with no materials on the components.
    Yes, I hope to add this to the UI soon to make it easier.
  • Hi Victor. That would be great. I've been away for a while...can you tell when this feature will be available?
  • Hi Victor, I would also apreciate that feature very much and i guess many other's, too
  • The next version (14) will have a stress-strain curve.
    Could you two, and anyone else here, tell me if you prefer the strain input to be plastic strain (0 at yield) like CCX does or total strain (yield strain at yield)?
  • I vote for “ total strain. “
  • I am not really sure. I am a bit closer to CCX, why I prefere more for CCX definition
  • Thank you Victor. I'd prefer total strain!
  • I prefer to be plastic strain only to keep in line with CalculiX documentation
  • Thank you as well! I would like total strain as well, especially with the recent speedups. Having a linear part to speed up calculations as well as a non-linear part does not seem as important with the speeding up of the computers, solvers, Mecway and Calculix in recent times. Probably more speed up on the way due to larger memory on GPU cards and faster Pcie busses and different (more adaptive) software models. Can't even go get a cup of coffee while waiting for a solution with Mecway and Calculix. Also most of the materials I use are not precisely linear at all (carbon fiber is close), just defined that way by code to simplify calculations.
  • Hi. Could we get both? :)
  • make it selectable :-)
