Hello, I have a few questions about how to access the python interpreter that comes with Mecway. I have never used ironpython before.
I'd like to be able to install packages using pip, create virtual environments, and that sort of thing. I believe all of this should be possible, since there is an ensurepip package inside of the Mecway13\IronPython.2.7.9\Lib folder.
It appears that unlike cpython, in ironpython there is no python.exe. Instead, I only see a DLL file in the ironpython\lib folder. However, reading online it appears that ironpython does use a ipy.exe (rather than python.exe for cpython). But I cannot find any ipy.exe file on my machine anywhere.
It is probably obvious that I have never done any .NET development before and have no idea how to access the equivalent of the python executable that comes with Mecway. How can I do this?
I installed IronPython and it pulls the resources that I needed in Mecway in order for the modules to work.
If you want a bit more complex python example, I have created a script in python to calculate average bending moments / length (either u or v direction) from surfaces ( mainly using 'quad8' in Mecway ) and get the number of reinforcement bars on a certain length - see attached file.
I wrote an explanation in front of every command so you can understand what is doing. If you have .NET or Visual Basic experience, the logic should be quite clear.
In order to work, please change the extension from '.txt' to '.py'.
Hope it helps.
Perhaps that would be possible by having a wrapper Python (even Python 3) library that starts an instance of the Mecway application then interfaces with it. But that's a whole different architecture which I don't intend to develop.
Third party packages could be "installed" by copying the files to site packages folder, but pip is so much easier to use.
