Hi All,
I haven't purchased this product (yet), so I have not had the opportunity to 'play'... Apologies of the answer is self-evident within the software suite.
My question is, what software and methods are available to introduce mesh refinement in Mecway?
Thank you,
-J Eppinga
If you're starting from a STEP file, you can define spherical and surface refinements that get applied when you generate the mesh. You can also specify a global maximum element size.
For any mesh, there's a Refine x2 tool which does local refinement on selected nodes/faces/elements, or global refinement. The local refinement is subdivisions and using templates to replace adjacent elements with transition mesh.
There are also some other refinement tools like Mesh tools -> Refine -> Custom which allows you to choose a different level of refinement in each direction.
Finally, there's Unrefine x2 which reverses the effect of Refine x2 only in cases with no transition mesh, such as global refinement.
