For a 3D model I want to rotate the model about the coordinate axes. For example, from the default isometric view, rotate the model 37 degrees about the Z axis, 42 degrees about the Y axis, 15 degrees about the X axis. These could be implemented simultaneously (with a dialog box) or sequentially (by mouse or keyboard). If 1 degree increments aren't possible then 5 degree increments might be acceptable. Neither F4-F5 nor Alt+Arrow do what I want.
After I achieve the above orientation and after zoom/pan as needed, I want to save the view. Then when I modify the model I can return exactly to the same view (e.g., to look at displacements or stresses). This is important when preparing reports to show progress in optimizing the design.
If the above aren't possible in Mecway then is there a suitable post processor?
Don C.
(In Paraview, the "Adjust Camera" dialog box can be accessed via the camera icon in the ribbon just above the graphics window.)
Also check out Paraview Glance
https://kitware.github.io/paraview-glance/app/
This is a neat little feature that lets you view a variety of results with full rotation, scale changes and a few other things. Can be very handy.
