I hope this is allowed on here.
I am running Salome 9.4.0 on Windows 10. It is doing that old favourite where it refuses to save the study. I have got around this so far but just using a different filename, but this has just stopped working, so now I can't save (could be related to file size, but I do have disk space). The last hdf successfully saved was 2.44 KB. I have dumped the study to a Python script, but this is just 20 KB, so I am doubtful as to what information is saved. Has it saved the mesh I have created?
I have tried to fix this before, but there are so many instances and different fixes out there it is hard to know which to try. I previously followed a fix which involved adding a line to a test file, but nothing changed.
Does anyone know which fix will help me?
Also any advice on saving the file I already have open would be welcome, or on what the Python dump actually retains.
Thanks, and happy new year to all, especially those with morons for a government.
Dave
"The issue can also append with temporary MED files created at study save. Removing loaded MED file from the study in SMESH module should solve this issue"
Also you could fire up another instance of the program and import the script to see what you get
Martin, thanks also. Do you know how to find/remove the loaded MED file? I have no idea. I was worried about whether a second Salome instance would kill the first. Is it OK to start a second one?
The save error brings up this kind of thing in the Python terminal:
HDF5-DIAG: Error detected in HDF5 (1.10.3) thread 16836:
#000: c:\s\salome-9.4.0\sources\hdf5\src\h5f.c line 664 in H5Fclose(): not a file ID
major: File accessibilty
minor: Inappropriate type
c:\s\salome-9.4.0\sources\medfile\src\ci\medfileclose.c [42] : Erreur A la fermeture du fichier
c:\s\salome-9.4.0\sources\medfile\src\hdfi\_medfilecreate.c [98] : Erreur A la crAcation du fichier
c:\s\salome-9.4.0\sources\medfile\src\hdfi\_medfilecreate.c [98] : C:\Users\dstupple\AppData\Roaming\158850\_SMESH_Mesh.med
c:\s\salome-9.4.0\sources\medfile\src\ci\medfileversionopen.c [107] : Erreur A la crAcation du fichier
c:\s\salome-9.4.0\sources\medfile\src\ci\medfileversionopen.c [107] : C:\Users\dstupple\AppData\Roaming\158850\_SMESH_Mesh.med
th. 0000007EEA6FF8E0 - Trace c:\s\salome-9.4.0\sources\smesh\src\drivermed\drivermed_w_smeshds_mesh.cxx [1001] : The following exception was caught:
c:\s\salome-9.4.0\sources\smesh\src\medwrapper\med_wrapper.cxx[106]::TFile - MEDfileVersionOpen('C:\Users\dstupple\AppData\Roaming\158850\_SMESH_Mesh.med',1',4',0',0)
I tried several variations of
_SMESH_Mesh.med.close()
In the Python terminal in Salome, but I get an error:
NameError: name '_SMESH_Mesh' is not defined
I think I'm going to have to restart Salome and import the latest version of the mesh that I exported.
Pretty sure I have run two instances at once before
As for using Salome I have found it very good for meshing but I always import atleast 90% finished model then partition and fix to get the best mesh
MANUEL
I just clicked on the download link I found in the site.
Then I just copied into my hard disk. I run it. I the files are finally saved as it says.
However, I have not done any deeper test yet.
MANUEL
