Temperature dependent mechanical properties
Is there a way to input temperature dependent mechanical properties in static analisys?
  • edited October 2020
    use ccx, custom model definition.
    define minimum properties in Mecway; there are some missing "don't generate" commands, for example you can't "don't generate" *EXPANSION, so only define these in the CCX custom file
    see example
  • Thank you JohnM for your help! The "don't generate" comands are needed or I just need to use "custom model definition"?
  • The "don't generate" commands suppress any material commands you have already defined in mecway, since you will be redefining in custom model input. So define the bare minimum just so that mecway doesn't complain, then suppress whatever you have created.
  • Thanks a lot JohnM. I'll give it a try!
