I have a flat plate with some holes that varies in thickness from 1" thick to 4" thick. I am trying to create a .liml file generator in excel similar to the mesh generator that is in the sample files. Could the analysis be done using the shell options for materials using quad elements or 4" too thick? Suggestions please.
With the internal solver, thinner shells are usually better and "thin" depends on the other dimensions of the part. If the plate is much bigger (say 10x 4"), then it's OK. However if the holes or other details are smaller, say 1" diameter, you may be losing accuracy in the stress in those regions compared to solid elements. The internal solver's shells use the plane stress assumption and that won't be valid for a small detail on a relatively thick plate.
Not clear if one plate has multiple thicknesses but if so, consider the transition between thicknesses. Shell elements won't capture the stress concentration there properly, which is OK if you're not interested in that or if it doesn't even exist on the real plate.
