I've been doing a lot of reading in the CCX user manual and noticed that there are options to support surface to surface radiation by using *RADIATE and support for time varying view factors using *VIEWFACTOR.
Does anyone have experience setting these up in the context of MECWAY's use? Victor, are there plans in the future to support this physics mode?
In the mean time, here's an example doing it by hand. It's a bit of work, something like:
- Make the model using ordinary radiation.
- Solve.
- Open the .inp file and copy the *RADIATE card with all its data.
- Use search-and-replace to change Rx to RxCR on each line.
- Copy and paste that new *RADIATE card to CCX -> custom step contents.
- Also copy the *PHYSICAL CONSTANTS card to CCX -> custom model definition.
- Suppress the radiation which was only there to generate the data for editing.
This would be much simpler if you could use a surface as described in the manual instead of a list of elements, but I can't get that feature to work.I don't know about using *VIEW FACTOR but I would imagine it's possible by adding the card to custom step contents.
As far as the *VIEWFACTOR card goes, I think this maybe called by the *RADIATE card when using the RxCR automatically but it's unclear to me from the manual.
