Curve generator suggestion
If in "curve generator" I set units to inches (as an example) and click on "center and start point arc" (as an example), in the opened window units are in meters.
It would be useful if in the new window default units were the same as the units set in the curve generator window.
When I click OK and return to curve generation window, equations are in meters instead of in inches.
It may be better if unit remain the same as before.
Just suggestions.
  • I realize it's a bit inconvenient but I probably won't change it because of priorities. Really, the predefined shapes are just there because they used to be hard coded and I included them in the curve generator to avoid removing existing features.
