Option Write results to liml file
Victor, using CCX as solver have tested the option ""Write results to liml file...", but in a small model, what I have is the results on the same file, and an exact copy of the model and results in the second file. I would suppose to have just a second file with only the results.
On the other side, in a long run problem, that I knew that solves succesfully, in the middle of the run CCX exists due to been unable to acces the .frd file to write results (when Mecway tries to write the results on the second file..but in the middle of run). This same beavieur (CCX exist due to frd unavailable to write) happens sometimes when I try to load the partial results during a long run.
  • Having the model too is useful in case of saving it over the original file. Is the problem that it makes it slower to get to the solution when you open it?
    It's strange that Mecway tries to write the results before it's finished. I don't know how that could be possible without CCX exiting first. Are you sure it happens in the middle of the run, not immediately before the end so that perhaps CCX hasn't properly finished shutting down before Mecway jumps in to read the file?
    Concerning problem with the button, I should be able to fix that. Thanks for letting me know.
