Hi Victor,
I got a chance to run a quick model in v12 today. Not sure if you changed something, but the graphics are a lot nicer than before. The smooth stress contour looks really good. I have a laptop with an AMD APU, so nothing fancy graphics-wise on my end.
I had a suggestion though. I had a model with a lot of forces and moments applied to different nodes. I wanted to run it with and without the loads. I had to individually select each one and say suppress. It would be nice if you could click the first one, hold down the shift key, click the last one, then select to suppress all in between. Also, if you could hold down control key and individually selected different ones, then select to suppress. It would be a lot faster and work like windows normally does when in file explorer. Hopefully, that makes sense.
Anthony
