Bolt Assembly Example
Attached is an example of a bolt assembly. It is to show how to set boundary conditions and contact. I compared to a standard M16 Class 12.9 bolt and got great agreement with standard bolt calculators. I was not looking to analyze the bolt and nut thread stress. This is to load two plates and look at the bolt deflection and stress. The thread stress is already taken care of with standard bolt calculators. That is where the proof load comes from. So it's not to re-invent the wheel but to properly include them in your model when you need to.
  • edited June 2020
    I was looking at this file recently and noticed that it is sized twice as big as it should be. The radius inputs where supposed to be diameter inputs. The tightening torque was off by a factor of 10. I had the decimal place moved over by accident.
    It took me several days but I finally got it updated. I have been running into persistent memory leaks and meshing problems with Mecway. If I mesh in Netgen and import the vol files, the meshing problems go away. The only way to deal with the memory leaks is to close Mecway and re-open it.
    I did my best to size the geometry correctly. It is supposed to be a hex head M16 coarse pitch 2mm, 50mm full thread bolt. I looked around the internet trying to find dimensions and properties etc. The original model I was trying to get the same bolt and nut but with a fine pitch. I noticed some of the specs only seem to be available for coarse thread. I think I had mismatched specs before. That's solved now.
    For some reason, the online bolt calculators and what I see with FEA are very different. For just the bolt, not in an assembly, there is a factor of 3 difference between FEA and the online calculators. With the assembly, there is a factor of 8 difference. These factors constantly shift as well. It depends on the geometry, the mesh, material properties etc... I sized the preload and tightening torque based off the FEA models.
    The example is meant to show how to setup contact so that you get the twisting and the tension in a realistic manner. I wasn't trying to re-engineer the bolt and nut. Moreover, the threads where purposefully left out.
    The original model was a much higher resolution. This model was intended to be coarse. I replaced fillets with chamfers to save mesh density.
    I gave up with trying to get the contact to look better. It is splotchy in places. I tried over and over, but this is the best I could do. You may have better luck with it.
    Contact and cyclic symmetry are both so much easier and faster in ANSYS. This type of analysis isn't well suited for Mecway and CCX, in their current state. This is around an hour to do in ANSYS. I spent several days on it and still not really happy with it.
    I added a lot more information and files to the download, to make it easier to follow.
    updates below
  • I have had to reconcile things like the BOLTCALC program, or weld stress calculators, spring stresses, microprocessor junction temperatures. The issue is the same - there is a "handbook" approach and then the FEA result. In most cases I have found that you need to calibrate a failure criteria that is consistent with the "calculators".
    I have attached a Mecway model of pret1.inp from the CCX verifsamples. It is essentially the original pretension section command first developed by ABAQUS in the 90's (which is what gained them all of the automotive market share). It works, but it's not easy to implement. I have found the thermal prestress trick to be good enough for our purposes, but if we did a lot of bolt assessments, I might be tempted to build on pret1.inp.
    I have a very different experience with contact. When there is "splotch" in the results, it is often the result of large variation in mesh size / insufficient density. I used ANSYS for decades and got used to that mid-side node "overshoot" in contact patterns. Commercial codes now often mask this effect with postprocessing - it's real, they just hide it.
  • Thanks John,
    I'll take a look. I am definitely being limited by mesh density. I tried numerous models before I arrived at the one with chamfers. That's about the best my computer can deal with.
    I experimented with contact stiffness last night and got results similar to the first model. Where you have the nice stress and displacement detail. About '1e6 GPa/m' for the 'Contact' pairs seems to work good. The default Mecway was giving was '2000 GPa/m'. The first model had increased inputs for those values too.
    Instead of the 'Tie' option for the 'Bonded Contact' pairs I'm going to experiment with the 'Elastic' option and see if that helps with the splotchyness.
    I've never tried to compare to the bolt calculators before. Given how long bolts and tightening torque tables have been around, I have to believe those are the numbers people use most of the time. I'm not yet sure why I'm so far off. I may be missing something there.
    One nice thing with the actual Netgen program is it has element quality plots. Each part meshed very fast and with a good quality. So I at least no there shouldn't be an issue there. It would be better to use fillets instead of chamfers though. I had to make that compromise.
    Something is going horribly wrong with Mecway's inbuilt Netgen, both the 'Netgen' and 'Netgen 6' options. It's having real problems generating meshes. I've lost days many times due to bad meshes. When I tried with standalone Netgen all the problems went away.
  • edited June 2020
    so in the original model i used '1.2e4 GPa/m' for all contact stiffness inputs. That seems to work very nice with the updated model too. I'll post an update soon. But no more splotchy results. Nice stress and displacement contours through the parts as well.
    There are a lot more contact pairs though. So run times go from 2.59 to 7.47 on my computer.
  • edited June 2020
    here is the latest version. once i changed the stiffness for all contact inputs to '1.2e4 GPa/m' I also changed the plate materials. The goal was to bolt an aluminum plate to a stainless steel plate. I was able to do that. One nice thing with the Mecway files in the download is you can easily scale the proof load and tightening torque inputs. I'm not sure why they are so different than online calculators. However, I wasn't really trying to compare them. Now that I see they are so different, I'm curious though.
    It's hard to see how the online calculators can be that accurate. Just changing the plate materials drastically changes the bolt, washer, and nut stress. Other significant changes come from material properties and boundary conditions. So a simple proof load and tightening torque calculation seems hard to believe right now.
    Updates below
  • edited June 2020
    Below is the latest version of the files. I made some updates to the standalone bolt file and the Mathcad file. The difference from bolt calculators is around 3-8 depending on single part or assembly, as well as how the assembly is setup.
    Updates below
  • edited June 2020
    So this is interesting, I guess. I made a different model of just the bolt. The the bolt without the head but still had the chamfers. This changes how the fixed bc operates. Then just the shank. So pure tension of a 16mm rod. The only one that matches the online bolt calculator is the tension in the shank. The stress in the hex head is about 3x higher than that for the single part. Then about 8x higher in an assembly. The scale factor of difference between online calculator and FEA depends on a lot of things. I ruled out mesh density as a cause.
    Wow, after further study, this is pretty crazy. This is a great use of FEA. Only a rod will match the bolt calculators. Changes in BC change the results a lot. If you model the head of the bolt, like I have, then the results change dramatically. The stress seems to go up because the head of the bolt is not infinitely rigid. Also, how the BC changes things too.
    So I did even more tests and what I'm seeing is very consistent with the topic of fillet concentration factors. Various setups I've seen 3-8x more stress than in the shank of the bolt. The online calculators seem to be referring to the shank only.
    It doesn't seem like the torque tightening specifications take into account the fillet stress concentration. Some of the calculators try to account for the type of joint. However, I definitely prefer the FEA approach. You can really see what's going on.
    I've never worked with torque specs for bolts before. I don't know if anyone has any insights.
  • edited June 2020
    I experimented more with contact stiffness. 1.2e4 GPa/m seems a bit soft. 1e6 GPa/m and 2e6 GPa/m work equally well. However, you start to get some of the splotchyness back. So you can set that value as you see fit. Not too much diff on results. 1e6 and 2e6 performed the same in my tests. The stress went up some with 1.2e4. The softer input causes the parts to overlap. It doesn't look right visually to me.
    I also made higher mesh density models and the splotchyness was not present at 1e5, 1e6, and 2e6. Based on all the testing; using chamfers, 1e6 GPa/m, and a good quality mesh should work well. Unfortunately, the attached model has a little bit lower quality mesh. I was trying to get the mesh as small as possible. The high number of contact elements, 200-300k, is what's slowing this particular model down.
    I'm confused as to why the online bolt calculators work from the stress in the shank of the bolt, rather than the peak stress in the fillets.
    Updates below
  • edited June 2020
    i think i found the problem. i re-checked the source file i had for dimensions and the fillet radius is not clear. one dimensions indicates .85mm, which the fea showed was way too small. another callout says 3mm, which is geometrically too big. i used the washer size to figure out a good guess. that was 2mm. when i ran that in fea, everything looks good. there are some stress concentrations in the bonded contact that throw the legend off. but if you probe the values, at the chamfer and shank, it looks good.
    so if you are trying to analyze the bolt stress, you really need a good dimension reference. i couldn't find anything too good. but this is working and still shows how to setup the contact.
    as with before, i used 1e6 GPa/m for all contact stiffness values. the min mesh size was .4mm, which is the chamfer size i put on the parts to avoid re-entrant corners. i meshed in netgen and imported the *.vol files. the mecway built in version is having problems. this makes setting up everything a lot harder, but at least it works.
    the large number of elastic contact pairs is what slows the solve down and makes for a good benchmark, as others have found. so this model can still be used to benchmark. on my crappy laptop it solves in 10 mins 32secs with two cores. i'm using the intel mkl pardiso ccx non-linear solver.
    so the online bolt calculators are fine. i figured they would have to be. bolts and threads have been around forever. the critical dimension is the bolt head fillet. i used chamfers to save mesh size. i can't solve large models on this computer.
    updates below
  • edited June 2020
    i added more chamfers where needed. decreased the min chamfer size to 0.2mm. 0.4mm was too big for the new locations. the min mesh size is still 0.4mm. pretty much the same results. however, the model is huge now. it took 25mins 57secs to solve. so it will make for a good benchmark also.
    note; based on the stress results, a grade 4.6 bolt would be best. you could load that to .75% of it's proof load and the aluminum plate and stainless steel washers wouldn't be over stressed. the highest stressed part is the washer at the bolt head. the next highest stressed part is the aluminum plate. i ran stress on just the plates and the results are significantly different than running the whole assembly. it's best to run the whole assembly, since the plate and washers get more realistic loading. running just the plates is 10x faster though. the final loads i used were 46kN for the axial force and 146Nm for the torque. i made a torque calculator to relate the force and torque, using the same formulas as the online calculators. i changed all the contact stiffness values to 1e5 GPa/m as well. to run the plates by themselves, i split the surfaces where the washers contact the plates. those models aren't in the download.
  • edited April 2023
    I updated this example again. Since others started using it as a benchmark, I went ahead and ran it with PARDISO and PASTIX. There is a spreadsheet that has the results for my laptop. The mesh is set to the highest that will solve with 16gb of memory. If you have more memory, you can update the mesh. Below, are a few pictures of the results.
    Edit:
    Someone once asked for the CCX inp files of this example. So I added them to the download. I noticed that I didn't update something in the spreadsheet that I meant to. I fixed that now. This was the note on max number of equations. It seems to be about 22 million for 16gb of memory. I added a pdf version of the spreadsheet, in case you can't open the spreadsheet. I also added sub folders, to make it easier to find things of interest.
    P.S.:
    I should probably say that the part dimensions are different for each of the updates. The original post had a CAD issue. I thought I was entering diameter values, but they were radius values. So the original upload is way off from what I intended. Update 2 fixed that. There was a question as to the bolt fillet head radius. I went with 2mm as that gave more of a contact patch. However, the actual value is said to be 3mm. So in Update 3, I used the 3mm value. This decreases the contact area and causes a much higher stress to form in a different location. Update 3 seems to match the standard bolt calculators really well, if you look at the first thread bolt stress, near the top of the nut. The FEA model shows the bolt head fillet stress is much higher than that though. The stress, in the contact area of the bolt head, is the highest. This seems like a reentrant corner to me. However, all the drawings I have seen seem to have this. All the parts are well within their allowables though. The FEA model was useful for showing that to connect an aluminum plate to a stainless steel plate, you would want to use a Grade 4.6 bolt. Otherwise, the aluminum plate will get crushed and fail. I spent a lot of time experimenting with the contact setup. This was the best I could come up with. It isn't too different from previous models. I applied the bolt torque differently this time. This was to get the motion I was looking for out of the bolt. All the parts are moving the way I want them to. If you look closely, you will see the bolt and nut turning in the correct directions. Also, the bolt elongates and the nut moves in the opposite direction.
    This version of Mecway does a worse job of showing the cut plane. There is some sort of reflection that wasn't in older versions. This makes the cut plane view look a lot worse. So I didn't make animations of this version. I just saved some images.
    This time around, PASTIX was faster than PARDISO. These are my benchmark results:
    Computer Type; Low cost laptop
    CPU; Intel Core i5-1135G7
    RAM; 16GB LPDDR4
    CCX set to use four cores
    Intel MKL PARDISO Solver; 10 mins 11 sec
    PASTIX Solver; 8 mins 54 sec (12.6% faster)
    The ssd is about 11x less bandwidth than most computers. The memory is about 3x less bandwidth than most computers.
    The times I use are from the Mecway output window, after it has finished processing the results. You will notice the CCX run times are not the same. Also, the Mecway time will change. To match what I have shown, wait for it to completely finish.
    The run times vary a lot on my computer. I sometimes saw an over 30% speedup using PASTIX. You would have to do a lot of runs and take an average of each, to get a better idea. I didn't want to spend that much time doing that though, as I didn't want to stress my laptop that much.
    At one point, during a PASTIX run, the solver caused my computer to reboot mid solve. This happened with a higher node count. PARDISO just goes to out of core. Then I have to manually kill the process, because it gets way to slow. Victor has mentioned you may need to apply a patch to get out of core working with PARDISO.
  • edited April 2023
    i accidentally found a really nice view of the results. if you look at the tensile stress, and reduce the max contour plot value in the legend, you get a plot that looks just like text book but with more detail.
    this is a cut plane view, so there are missing elements that cause some jaggedness.
  • 4:45 PASTIX Intel i5-12500 3.00 GHz 64GB using 6 proc
    6:31 PASTIX Intel i7-10700 2.99Ghz 32GB using 6 proc
  • Ryzen 9 3.3 GHz 16GB
    00:09:18 PardisoMKL OOC
    00:05:16 Pastix
  • edited February 24
    Found this old thread by chance -
    “I'm confused as to why the online bolt calculators work from the stress in the shank of the bolt, rather than the peak stress in the fillets.”
    It’s due to the typical failure modes of bolts. Most bolts are fairly ductile, so some yielding at the fillet at the head is acceptable. Most bolts fail in net section tension (external force is greater the ultimate strength of the cross section of the shank) or fatigue at the first thread in the nut/threaded part (high fatigue notch factor - stress concentration).
    A properly torqued bolt sees very little of the external load, as most of the external tensile load is used to reduce compression in the clamped members. Therefore, fluctuating external loads have little effect on creating an alternating stress in the fillet at the head, which is less severe than in the thread, and subsequently bolts rarely exhibit in-service fatigue failures at the fillet.
    For fatigue evaluations, the peak stress at the first thread is usually determined by multiplying the calculated stress in the shank by an empirically derived factor of 3-4, depending on how the threads are formed.
    Hope this helps!
  • @c3d10
    thanks. bolts are rather interesting. the fact that they are installed near their failure point had made me wonder why they don't break as soon as an external load is applied. you're explanation makes sense.
  • Some very high strength bolts such as used in aircraft and some machinery have a reduced shank to keep the stress lower in the threads, because of the strain concentration at the root of the threads aggrevates fatigue, and have a fillet under the head for the same reason in that area. This also allows higher strain to be stored in the bolt making the prestress load of the bolt to not relax as much with creep. This is not usually the case for structural bolts used in buildings and bridges. In buildings and bridges at ultimate many bolts go into bearing shear, which would be sloppy fit with the reduced shank, and the washers under the heads would need odd holed to fit the fillet under the heads as well.
