Starting Mecway with user defined emty liml-file (templare)
Is there a way to define a kind of template liml-file.
I was thinking about the possibillity to pre-define different materials that then can be aplied to the model instead of new definition.
  • Yes. Tools -> Options -> Default model.
    You can also use File -> Import to add a model containing only a material to the currently open model.
  • Thank you.
    I didn't see that, sorry
  • Hengre-
    Check out the "Import from Library" feature that can be enabled in Labs, it lets you use your idea to great effect by keeping material files in a common place for your team.
