Tunnel model and analyze
Dear all,
I'm civil engineer and very new with Mecway. I have a mini project about excavation a small tunnel. I had a difficulty in create a correct model, apply load and boundary conditions for the geometry.
Happy to hear some advise and idea from your guys.
Thanh
  • Hello Thanh. Could you give more details about what you're stuck on? Or you can have a look in Help -> Tutorials which shows examples of applying boundary conditions.
  • Hi Victor,
    I tried to create a cube with 3 layers which represent for 3 layer of rock. When i assign material for the top layer ( with young's modulus, poisson's ratio and Density ) then run the model to see the affect of self-weight of the top layer on the second and third layer but the result is 0 on tress.
    Do you have any advise ?
    Thanh
  • You would also need a gravity "load" and a constraint somewhere, such as fixed support on the bottom.
    You're also welcome to upload the file to make it easier to see what's happening.
