What is the best way to incorporate the effect of air bearings between two surfaces? If the stiffness and damping of an individual air bearing is given, how can this information be used in establishing an interface between the two surfaces enclosing the air bearing?
For damping between two surfaces:
The spring or damper element options would only work for linear analysis because with large rotations, they'll start to apply rotational forces instead of purely normal.
