I have experienced an odd glitch while using MecWay's Thermal Steady-State Function, particularly in regards to FEA on
heated pipe segments. The problem involves a segment of pipeline insulated with fiberglass, heated by a thermal resistance cable. When I performed the analysis, the software not only mapped the temperatures around the cable, but also mirrored those temperatures on the other side of the pipe. Is this a glitch, or just my inexperience causing me to make an error?
EDIT: Since the Trace part has smaller elements, that should be the slave. That will cause it to connect continuously along its entire surface as well as only to the nearest part of the pipe. So by swapping the surfaces, there's no need to remove the opposite side from the selection.
