It is possible to apply a pre-stress in MecWAY?
I saw the non-linear static calculus in the manual where this topic is mention but I don't find any application example.
I want to pre-stress a truss element (like a cable) to show students the difference in stiffness behaviour in simple structures.
I can introduce equivalent forces of a "tricky" effect with temperature but I wonder if there is the option in Mecway to introduce the pre-stress directly.
Thanks in advantage
There's an example in the manual called SaggingCable.liml which shows this effect for a cable that has zero bending strength other than its prestress so it applies the prestress load first, then a gravity load begins at a later time.
There is a prestressed axial spring element in Materials -> Mechanical -> Spring but it's not available for nonlinear analysis so it won't show stress stiffening.
