I’m not sure to understand properly the meaning of the “Number of segments to output=All” inside the cyclic symmetry BC.
Once solved, only the seed sector is shown in the screen.
¿How can I get all sectors represented to check any strange behavior? , like the Impeller example in the manual where the whole Impeller is visualized although only one blade is computed?
*CYCLIC SYMMETRY MODEL, N=12, NGRAPH=3
0.,0.,0.,1.,0.,0.
Cyclic symmetry seems not allowed in Mecway with ccx. It turns red.
The inp file generated by Mecway does not contain CYCLIC SYMMETRY card.
If I import the previously "save as inp file" CYCLIC SYMMETRY seems that has disappeared.
¿Am I doing something wrong?
In Mecway Version 10, cyclic symmetry will work directly with CCX.
That is a small part of the complete dome with its supporting structure. It helps me to understand properly what am i doing before going to the complex geometry and waste too much time.
¿ Does it have sense to provide a number of sectors that do not complete the 360º ?
If I indicate 4 sectors they are "disconected" one from the other.
Seems there should be no need to ask for them. ¿Isn't it?
