Hi, I'm modeling a simple steel sheet part that is hanging by his ends, affected only by gravity load. In the real life this part is deflecting too much (about 10-20mm for about 2000 overall length, will measure later), so I need to increase some bends angles to make it stiffer.
Now the problem, I have modeled the part with three hexa elements in thickness, and using second order elements. With a lineal analisys I have 22mm of deformation, but with geometric no lineal I have about 7mm... is normal to have this stiffer results? I would say that no lineal results would be higher than simple lineal
If one end is free to slide horizontally, then I'm not so sure but I would think linear should have greater deflection because gravity only acts normal to the sheet, tending to bend it. Whereas for nonlinear, after it starts bending, a component of the gravity force will be in the plane of the sheet and not contribute to bending.
Since it's a simple solid model, perhaps compare to the internal solver too.
By the way, is there some issue for uploading files? I'm trying to upload some pictures from this morning without success.
Best regards.
