view fit to window is not working in latest version.
I clicked solve after adding some constraint equations. there was no results visible so i tried clicking view all. then went back to component screen clicked show all then view zoom all but still nothing is visible
also where I have two shells connected a along a line of common nodes at 90 degrees to each other how do i release them so that there is no moment transfer between them across this common edge
also when I have a 1d beam element supported by a node at the top of a wall shell panel how do i release the beam element so that there is no moment transfer between the two at the beam support.
There's no simple way to make a hinge between shells. Some ideas are:
A ) Use constraint equations to couple the displacement DOFs, like
Not practical for a large number of nodes unless you generate them externally and write them directly to the .liml file.
B ) Build a solid edge along the joint that's rigidly connected to one part (eg bonded contact or overlapping elements) and only connected by nodes to the other. Example attached.
For a beam, it's easier. Use Flexible joint on beam under Loads & Constraints. Check all 3 boxes to release all 3 rotational DOFs.
Not sure how i can easily generate it externally either. Its a pity that flexible joint only applies to beams. I was hoping it might be possible with new node rotation, say by entering -1 values meaning releases instead of fixity.
