No Results produced for cylinder buckling using internal solver but CCX results have
Victor, I run mecway for cylinder buckling using internal solver No Results produced but CCX results have results.
this confused me, any opnion,thanks!
  • it looks the forum closed the attach a file function that I can not upload the liml file
  • Sorry about the lost file, I don't know why. Could you email it to me?
    Did you set the Shift point under Analysis settings? Pick a number below the lowest buckling factor, the higher the better, but a very small value like 0.00001 should still produce some (wrong) result.
  • that's correct. when shift point setup,buckling shape appear, it is different with ccx results, internal solver brings up some duplicate mode that has very close number,any comments. Thanks!
  • The symmetry of a cylinder should cause modes of the same shape but different orientation. Can you identify if any of those modes are wrong (internal solver) or missing (CCX)?
