Is there a way to define a minimum element size when using automeshing-3d? I've been playing with importing some simple geometries in STL format but when I automesh it gives me a ridiculous amount of elements for the geometry I am importing. I am able to set an upper limit, but no lower limit. I want to start with a coarser mesh.
So to prevent many tiny elements, you would need to remove those features first. If possible, it's better to use a STEP file like prop_design referred to, then as well as more options, the loads and materials can be retained between meshing and curves can be reproduced more faithfully.
