Reactions forces when using CCX
Hello everyone!
Is it possible in Mecway to see surface (or node) reaction forces if my model is simulated using CCX solver?
Thanks in advance!
  • In version 7, node external force (including reaction force) x,y,z components are called FORC_F1, FORC_F2, FORC_F3 respectively and should automatically appear in the solution. The units are always Newtons.
    In version 8, they're called external force which is included automatically if you don't specify any field variables, otherwise you have to add it before solving. They can be displayed as arrows or contour plot and have selectable units.
    If you want to isolate reaction forces from applied external forces, then I don't know if that's possible.
