Hi Victor.
As a user of the Load Case feature in v6, which I liked a lot, I have just tried out v7 Configurations. A v6 model that previously contained 7 separate load cases opened with 7 configuration tabs automatically in v7, so backward compatibility looked good. However, now it appears each configuration, each containing a load case, has to be separately run. Each run seems to re-solve the stiffness matrix and boundary conditions, so what took x time to run now appears to take 7x. The model file (177000 elements, 51800 nodes), including results, is 50% larger and the time taken to simply open my model has gone from 1 minute to almost 10 minutes in v7 . My computer became so sluggish after running the model that I may have been encountering some kind of memory leakage (if that's the right term!)
It seems a shame that such as productive feature as load cases is be substituted by configurations which take so much longer to implement. I had seen load cases as a great aspect of Mecway; one that was the envy of my ABAQUS colleagues. Is it not possible to retain the capability of having a single solve of the stiffness and boundaries if there is no change in geometry? Or retain the option to run load cases in a single run?
Another interesting option playing with lineal load cases, is the possibility of create new results combining several cases, without using the solver, just working with the results.
Sorry for delay responding to query re paging to file. I was away.
Paging to file isn't significant; just the occasional flicker. But I think running Mecway on this computer in a client office (Windows 7 Enterprise 64bit with only 4MB RAM) is probably the problem. Typically the paging is at about 450MB with V7 but this doesn't appear to be different to V6. However, almost all RAM is consumed and remains consumed by Mecway after running is complete. Background RAM is at about 32% with Mecway unloaded, 85%-90% with a Mecway model loaded but doing nothing. Is that right that the model is held in RAM when it is not doing anything? I have noticed that after running Mecway (and the run is finished), my memory usage keeps climbing. I have no other applications open other than Mecway and Acrobat (to keep transferring my licence key between v6 and v7). Opening or running any other application with Mecway open is a non-starter; just too slow.
Not sure if of any help. I think the slow opening and slow running I'm experiencing is probably a function of this PC not being up to the task rather than an issue with Mecway per se. See attached graphic of my little time and motion study with task manager.
Notwithstanding, the need for each config requiring it's own run time (albeit with a single click) instead of all load cases run together makes Mecway analysis a slower process for me now. I'm drinking a lot more coffee!
Hi Victor.
The computer only slows once Mecway has a model loaded. I'll just close Mecway down to use other applications.
