I am doing modal analysis of a circular plate with thickness of 2 mm. Is it necessary to match geometry's thickness to the thickness defined in material?
No, you shouldn't need both. The thickness in the material properties is for shell elements and is ignored for solid elements. There, you would define thickness only by the geometry (node positions).
