Default Units
VMHVMH
edited September 2014
Victor, can we add an option for the working unit system being used? I'm working with imperial units but the default is SI units so the tape measure, global coordinates keep showing in SI units instead of imperial units.
  • Hello VMH
    Typically, if you've used imperial units in the model (except for the mesh if you reopen the file), the tape measure will show inches. It could be that it contains some metric lengths or no imperial units at all.
    A workaround is to start with a kind of template file that contains inches somewhere, such as in a material property. If you start with that then the tape measure/etc will show inches until you use other units.
  • Victor,
    Thank you. I'll look into it.
  • Victor,
    It works great. Thanks
