structural analysis of Composite laminates
I am new in Composite laminate  structures. . And interested in using Mecway  for Composite laminate analysis for static loading conditions.
Any case study or tutorial if available will help me to get some hands on .
Regards.
Dr Patil.
  • Here's a simple cantilever beam sandwich panel.
    Skin thickness = 0.2 mm
    Overall thickness = 10 mm
    Bending moment per unit length at the support = force per unit length * beam length
    = 20 N/m * 1 m = 20 N.m/m
    Mecway solution: Moment per Length U = 20.0 N
    Tensile stress in the skin:
    Because the skin layers are very thin relative to the laminate's overall thickness, we assume each skin layer is in pure tension or compression.
    Because the skin layers have a much higher Young's modulus than the core, we assume no load is carried by the core.
    tensile stress = moment per unit length / laminate thickness / skin thickness
    = 20 N.m/m / 0.01 m  / 0.0002 m = 1.0e7 Pa
    Mecway solution: Principal Stress 1, Upper surface = 1.04e7 Pa
    Mecway solution: Principal Stress 2, Bottom surface = -1.04e7 Pa
