Hi Victor, is possible to keep saved between sessions the Show Origin and Contour Resolution options? All the rest items on the Options window are saved but this two not.
These are a bit tricky. Contour plot resolution in particular. It was persistent in version 4 but several people turned it up to maximum then wondered why the display was so slow. It needs a way around this problem because the link between the resolution setting and speed isn't obvious and might not appear until months later when you run a bigger model.
