Hi, is possible to create new coordinate systems on Mecway's GUI? Something like the TRANSFORM card from CCX. I'm working with bolted unions and having a local coordinate system is a must for appling bolt preloads when they are not alignated with the global css.
Regards.
One of the problem that I see with the TRANSFORM card is to check if the directions are ok or not, having the cs on screen would help a lot.
Tomorrow I will try with the complete part and adding a second step to load the part and put in traction the bolted unions.
During some initial tests I have applied by mistake the load in the x direction (radial), and I can see that at the loading plane the part behave like if it would be separated. Now I don't know how it will work during the second part of the test when the bolts will be pulled.
Also, it would be nice if we could hide a selected set of elements. I had to use the cutting plane to see/pick the faces on my normal face, and that was painful. It seemed that I could not view the model any way I wanted when using the cutting plane.
