Pressure as XYZ components
Hi, I'm making a simple analysis using CCX and applying pressure on a set of faces. If use "normal pressure" the calculus run smooth, but If I change to XYZ components and only choose one of them, then when I try to solve I get the message
Error: XYZ pressure could not be converted.
And CCX runs but doesn't give me results.
  • The XYZ pressure load isn't currently supported for exporting to .inp.
