Beam Element to Solid Element in CCX
Hi, I haven't looked much into this yet. But, has anyone tried transferring all DOF from a beam end to a solid face using CCX solver and also Mecway solver and obtained reasonable results? See attachments. I know we can do this in Abaqus. Thanks
  • I though to sugest you to use TIE, but I just read in the documentation that is only for 3d elements. Then I though in MPC, but true is that I don't understant how to use according to the CCX docs. On the other side, in the Mecway docs, MPC looks usefull for the matter.
    I will follow this post to see how can be solved.
  • VMHVMH
    edited May 2016
    This will be an interesting topic for many who are using beam elements for the global modeling connecting to shell/solid elements for the connections/parts they are interested in. This give a better boundary conditions for more complicated structures (civil/structural engineering).
  • edited May 2016
    CCX doesn't seem to use the rotational DOFs in its constraint equations (*EQUATION) so this type of connection doesn't work correctly though it's OK with Mecway's built in solver.
    I've constrained it so only translational DOFs are relevant and it produces a sensible solution, liml and png attached.
  • Thanks Victor. I tried axial, bending, and also combined axial and bending. They all had localized stress concentration from the beam to solid element which wouldn't exist if they are all beam elements or all solid elements. Thanks
  • Bonded contact won't do that because it only connects the beam's node to a point on the master surface, rather than the whole surface.
    The poor-man's way would be to use multiple beams. Or you could probably do it using CCX's *RIGID BODY but that makes the surface rigid, which might not be ideal.
    I hope to add a kind of "soft" rigid body connection in future, like Nastran's RBE3 which would serve this purpose with Mecway's solver but I'm not sure how/if it can be made to work with CCX because of the lack of rotational DOFs.
  • VMHVMH
    edited May 2016
    Thanks Victor, I'm always interested in deformable rigid body/link. It's like dummy member I used in structural analysis software like SACS by Bentley that transfer loads but removed from the stiffness calculations (save and delete joints/members from the stiffness calculations).
  • How did you analyse this when i try i get an error, see attached. Appears to not be able to analyse it as a 3 point beam member.
  • davefo, which version ccx were you using. I tried the rerun my original model attached in above message and didnt see your error message.
  • That screenshot shows the internal solver, not CCX.
  • yes i was using internal solver produces the error. I thought the above was this worked with the internal solver, "though it's OK with Mecway's built in solver"
    when using the CCX solver i get the attached error. CCX version is 2.10
  • Oh I see. 3-node beams aren't supported by the internal solver. You should also clear any other red errors in the outline tree that can be ignored with the CCX solver.
    If it says "Solver did not produce an output file", click "CCX output" to see the detailed error message.
  • found the reason for the calculix error.
    I had pointed the solver path to the actual ccx.exe
    when i changed it to point to the .bat instead it now works.
