Attached are some screenshots of some nice features of Netgen 6.1 Experimental. It has automatic quad dominate meshing. As always you can also do auto tet meshing and generate quality plots. You can generate quality plots for the new quad dominate meshes too.
You have to have Python 3.5 and MS C++ 2015 Redistributable installed for Netgen to work. If you use the very fine mesh setting and change the min mesh size from 0 to 1 you get very nice meshes. I also have to run Netgen as administrator to avoid issues of things not working in Netgen. The snapshot feature doesn't seem to work.
