Openfoam Pressure Import ASCII BARAM v26.1
Hi there i have a question about importing openfoam results as pressure for further stress Simulation.
I have use it in Prepomax i for example the pressure of a traffic sign in a Orkan was solved in BARAM v 26.1 des Solution File was written in ASCII format not binary the import in Prepomax of the Foam file was no problem. Is the same Possible in Mecway? Thanks for every Answer better a approximate solution the no solution love ya
  • No, sorry. Some ideas, none of which are easy:
    - Fit it to a curve (somehow) and enter it as a formula in Mecway.
    - Convert the pressure data directly to CCX *DLOAD cards and put them in CCX -> Custom step contents in Mecway.
    The biggest obstacle is that Mecway doesn't currently have a way to represent a unique pressure value at each element face or node.
  • Okay thanks , what if i export the Simulation from Prepomax and import the *.inp into Mecway as a Workaround leave any comment thanks in advance
  • If it uses *DLOAD, it should work. *DSLOAD won't import into Mecway though.
  • IT works IT imports the pressure from BARAM v26 great next step buy Mecway until the end of Month love it
